Why isn't my Mini-Prep Plus turning on?
The chopper is not responsive when the chop or grind buttons are pressed.
좋은 질문 입니까?
좋은 질문 입니까?
Check and ensure that power cord is plugged in. If the power cord is plugged into a working power outlet and there is food inside the workbowl, try removing some of the contents and attempt use again. Failure to "turn on" may be caused by overloading the workbowl to a point where the contents prevent the motor from functioning properly.
해당 답변은 도움이 되었습니까?
Also, ensure the plastic tab of the bowl cover locks into the slot on the back of the machine. This will short the safety switch.
해당 답변은 도움이 되었습니까?
Thank you so much.
Saved me buying a new one.
Philomena
24 시간 전: 4
7일 전: 17
30일 전: 104
전체 시간: 5,446
I've only used this machine a couple of times and it worked perfectly. Went to use it today and no response. I've done all the trouble shooting tips.
cjdavis_98 의
