주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 질문 전체 보기
drove with parking brake on & now will not shift
It starts fine and runs smooth but it won't shift. It has a THM700R4 transmission.. Put in a new speed sensor, would like to know what other sensors I might try?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
kpgklm , How is your trans. fluid is the level correct(top up to proper level with correct fluid type if not), Does the fluid look dark or smell burnt, this would be a sign of warn parts/clutch packs inside transmission, possibly over heated from driving with park brake on. Other things could be plugged filter, collapsed/pinched trans lines, Trans. pan will have to be removed to check most, valve body plugged, bad/sticking governor/plastic gear(link#1), TV(throttle valve) valve stuck/ faulty(link#2), etc.etc.. If you do not feel comfortable diagnosing or working on the truck have a good Transmission tech. have a look diagnose and estimate repair. If estimate very high consider replacing trans. with a good used from an auto recycler. 3rd link is an article diagnosing GM transmissions. Good luck.
https://www.youtube.com/watch?v=PRdnl31q...
https://www.youtube.com/watch?v=WLfBZeOS...
http://www.lsxmag.com/tech-stories/diagn...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
kpgklm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 121
