Why won't my Samsung galaxy Mega turn on after screen replacement?
I have a Samsung Galaxy Mega 6.3 SGH-i527 and I had the LCD screen/ digitizer replaced. After that the phone won't go past the Samsung galaxy mega logo screen, it won't go into recovery mode but will go into download mode. Any advice would be helpful, thanks!
좋은 질문입니까?
댓글 6개
I have the same exact problem ant solutions?
Erica Gachuz 의
I have tried the deal, boot with old screen then swap em out. My replacement still won't light up. Only thing I have seen work so far was just the back light came on, but still nothing else. Is there any other "tricks" to try?
Rick Givens 의
You need to pull battery then power on with old screen and let it fully power about 10 minutes wait till the screen dims and goes off that's when you disconnect and after market one mines works every time. I have everything on the new screen I just pull the back cover and get my own screen Connect with ribbon power on and wait till it dims goes off then I just connect ribbon back being careful that I don't hit the power button or volume button just keep the screen off till you connect to my he screen. Works everytime.
tony pazo 의
Okay, I just tried this method and all I can get on the new screen is the back light. I do have a little trouble getting the flex to "clip" down. Could that be a problem? Or is it a defective screen? Too many questions, never enough answers...
Rick Givens 의
Are you sure you have the correct model screen for your phone? Compare the new and old screen together make sure you check if the connectors are the same too
Cory Branch 의
댓글 1개 더보기
