주요 콘텐츠로 건너뛰기
2013년 6월에 출시된 Galaxy Mega는 720P 스크린, dual-core 프로세서 및 8MP 카메라를 장착한 6.3인치 스마트폰입니다.
54 질문 전체 보기
Why won't my Samsung galaxy Mega turn on after screen replacement?
I have a Samsung Galaxy Mega 6.3 SGH-i527 and I had the LCD screen/ digitizer replaced. After that the phone won't go past the Samsung galaxy mega logo screen, it won't go into recovery mode but will go into download mode. Any advice would be helpful, thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 6개
I have the same exact problem ant solutions?
I have tried the deal, boot with old screen then swap em out. My replacement still won't light up. Only thing I have seen work so far was just the back light came on, but still nothing else. Is there any other "tricks" to try?
You need to pull battery then power on with old screen and let it fully power about 10 minutes wait till the screen dims and goes off that's when you disconnect and after market one mines works every time. I have everything on the new screen I just pull the back cover and get my own screen Connect with ribbon power on and wait till it dims goes off then I just connect ribbon back being careful that I don't hit the power button or volume button just keep the screen off till you connect to my he screen. Works everytime.
Okay, I just tried this method and all I can get on the new screen is the back light. I do have a little trouble getting the flex to "clip" down. Could that be a problem? Or is it a defective screen? Too many questions, never enough answers...
Are you sure you have the correct model screen for your phone? Compare the new and old screen together make sure you check if the connectors are the same too
댓글 1개 더보기
댓글 달기
답변 12개
가장 유용한 답변
You have to turn the phone on with the old screen still plugged up you then unplug the old screen while the phone is still on and you plug the new screen in and there you go it works perfect you just have to install it with the phone on
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Hey thanks it powered on just fine with the old screen then I just plugged in the new screen and it works! But will I be able to power off and back on????
So I have it powered on now thanks but my question is will it work after I power off or reboot or do I have to keep the old screen to boot it back up again?
댓글 달기
Go to eBay. & get the LCD/frame assembly. Then transfer ur parts over.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I transferred over the LCD/digitizer and frame and after I put my battery in the phone turns on by itself shows the Samsung logo and shuts off I take out the battery again and it does the same thing it won't turn on at all please help
댓글 달기
Try to get root the phone to see if it's the problem of firmware.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How can I do that?
댓글 달기
often, the screen was not meant for android 4.4, if your phone has android 4.4, the the screen may not be compatible wit it. I was looking for a replecement screen for my mega, but no luck finding one for android 4.4. That is probably the problem, but i cant help, sorry
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thanks anyway
Hi.. im using mega 6.3 and its working perfectly but im just bothered because the four edges of my screen is overlapping from the phone itself.. for me it looks way more cooler because it has sharp edges than the roundy shape of the usual ones..but I just really want to know if my screen is normal or this is a replacement screen..thanks in advance..
My mega screen cracked i replaced it ...it was working fine then it turned off and wont come back on?? Can u tell me what might be wrong and os it fixable?
댓글 달기
Thanks man. It works. After two time new screen order for noting
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My samsung galaxy mega wont start or if it does. It wont go past the samsung screen can anyone help me please.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I am having the same problem IT want do anything it's just stuck on samsung screen please help
댓글 달기
hi I have a Samsung mega I changed the digitizer and screen it worked then went on to a warning then it shut down and now doesn't do anything it doesn't even charge
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you need orginal screen to work in new version 4.4.2
if you can't find orginal lcd you can downgrade your software version to 4.2.2
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How do you downgrade if splash screen is all you can get and don't have the oem display? I'm at a dead standstill here!
댓글 달기
Hello I'm having the same problem. I switched. The lcd and the touch screen didn't work was that the lcd just wondering
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mine doesn't even work with the old screen. Still showed my background after the crack, then swapped it over and won't power on in either phone at all now. I fix a ton of megas and have never run into this problem until my personal one got destroyed....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I replaced only the digitizer on my mega 2 and it started freezing on the first menu, i am now trying the old digitizer and its still doing the same thing, any suggestions? I didnt feel the need to replace the lcd if it was still good
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Seems that if you have a replacement screen in the mega it will boot loop solution is to power in with the old screen and after it powers on connect the new one and it works! Well done hats where I'm at now dunno if the phone will reboot again I haven't even attempted it yet! I'm letting the battery fully charge and hope fully I can install root and custom recovery! I have the mega i527 AT&A variant 6.3. So if anyone can link me to a working custom recovery for this model i527 I would really love appreciate it. Thanks a mil
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Tunyia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 8,980
