주요 콘텐츠로 건너뛰기
The Lenovo IdeaTab A2109 is a 9-inch multi-touch screen tablet released on August 27, 2012.
9 질문 전체 보기
My tablet wont boot or charge
When i plug the tablet into the charger there is no response and when i try powering up i get a quick flash and vibration alhough it doesnt boot up, i have tried holding the volume+ and pressing the power button for different lengths of time and still nothing, the product is a little over a year old, it is a 'lenovo tablet pc ideatab A2109A-F' model:2290, any help would be great thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 달기
답변 9개
가장 유용한 답변
i have same problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
my tab is continuously booting. how to stop that
. lenovo idea A2109A model
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Had same with A3300-hv just press volume up and down and power off button together it will work for booting
댓글 달기
MY Lenovo IDEATAB A2109A is booting continuously when i swictedon and iam unable to any program with that pls help me to resolve this problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The problem could be you battery or io port if you don't feel vibration. Its possible that the screen might not work too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have this same problem and everything I try to do it just doesn't work
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my screen wont turn on or take charge any more
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Has anyone thought to check the USB charge port by wiggling(GENTLY) . to see if a solder contact has failed???????
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello! First try charging for 5 hours after doing it while plugged press volume up and down and power on/off button together you will get a vibrate ! . its a good sign. Try again for 30 seconds . Hopefully this will work!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
che gee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 3,106
