주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Dock melted a spot on cover and smells like burnt. Won't hold charge
I had placed my iPod to charge on a docking station. Noticed battery was dead when looking closely at it it had a spot on the front cover like it got too hot and melted. Took it to apple they said all is fine inside but not to use the same dock again and that the battery just got way to hot when charging. Not holding a charge now and my iPod is all I have with my music, pc crashed don't want to hinder loosing my music. Can anyone help me I'm afraid to ruin it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 6개
가장 유용한 답변
I would agree that it was a bad answer problem stands that being I am a lady I just got the brush off when I asked questions about replacing the battery and if it would work after doing so. Guess I wasn't good looking enough.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Bad answer from Apple. Get some good looking young lady to take it to Apple and get them to replace the unit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sounds like your dock cooked the battery.
The high thermal energy from the dock most likely heated out the ions in the electrolyte of the battery, no ions, no charge.
Only option is to replace the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thank You for you responce that helps me understand I will do just that and change my battery. Greatly Appreciated. Bea
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have replaced the battery an still dies quickly. Thanks for the insite. greatly appreciated.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
since the replaced battery still dies quickly, the logic board - or the dock connector - has one or more parts shorted together/toasted/bbq'ed. finding that part shouldn't be the problem - but replacing it would be pretty hard. you need someone who does component level repair every day - maybe you will find someone in your area (but i don't know if you could find those people in the yellow pages)
good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
classy50s 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 1,281
