Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1546 질문 전체 보기
The touch is erratic even after several screen changes?
Hello my Ifixit family!
Received a Iphone 5C that a customer wanted to change the screen on, nothing unusual..
First thing I noticed was the water sensor on the back of the LCD was a little pink. I switched over the parts and put on the new screen and everything seemed to work fine.
Then, 2-3minutes later of testing the screen started acting very erratic. It was extremely sensitive to the point where I could use an app without even touching the screen (simply hover my finger directly over the screen resulted in the app starting up)
I've switched out the screen 4-5times now, sadly I don't have another unit to test the screens with though. However I'd also like to point out that the 2 of the screens are from a different batch. So I can't imagine the problem being screen.
Any ideas? I tend to only restore the phone as a last result thing..
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
I have a similar thing but it has happened with multiple iPhone 5Cs. None of the iPhones are liquid damaged but i have had a few where the screen is just erratic a few hours after changing it. I have tried screens which I know 100% worked before but the customer still comes back and says that the screen is erratic. I'm tearing my hair out! Is it a software issue?
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
Hello there only a problem iv ever seen on the iPhone 5.
Can u turn the phone on when the screen is at a 70 degree angle and see does it still ghost touch
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Hej Con, thanks for the answer.
When the phone screen is lifted at aprox 70* I could not recreate the ghost touch problem. I tried for aprox 5min and it worked the entire time.
의 답변
의견 추가하세요
Ok something is shorting the screen out when layed flat see in the pic does your screens come with the black tape over the circle in red?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
That was my initial thought as well, however it is indeed covered with tape. There is also still black tape covering the vibrator in the upper left corner.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Alexander 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,540
