주요 콘텐츠로 건너뛰기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
185 질문 전체 보기
lg g2 won't turn on, only vibrates
lg g2 won't turn on, only vibrates when i am pressing the power button
Please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
I have the same issue! I replaced the screen and its doing nothing but does vibrate sometimes. So I'm sending the screen back and thinking it may be possible bad replacement part.
댓글 달기
답변 4개
가장 유용한 답변
When I had this problem, it was the battery. It was completely dead and required an official charger to charge the phone. Worked fine once it was charging with an official charger.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had the same problem, but thank god I'm an Verizon employee. I let it charge all the way and then it worked fine!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Still vibrate, so there is the power. If the charging LED light come on when plug charger? It's more likely there is something wrong with the LCD screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I dont know, honestly. Ive been having the same problem. None of the above solutions help. It vibrates when charged and when the power is held down. No LEDs turn on, and the screen is just black. The only sign of life from this thing is vibration.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Subba 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 24
전체 시간: 11,455
