White lines that fade in after battery replacement
So I had a battery problem the phone pretty much would die (just shutdown on its own, the more apps I opened the faster) 10 minutes after it would leave the charger. Even with a full battery icon and then would occasionally turn back on and then off again or just need a visit from the charger all together.
I ordered the Battery Replacement Kit and went to work, when I got to the battery I noticed white residue coming form the top left of the old battery near the volume controls and all over the back of the metalplate of the display assembly. I cleaned out what I could and removed the old battery which was soft and seemed to have exploded?
So new battery installed just about finished up the last steps of reassembly. Turn the phone on and on the boot up screen are to 2 white glitch lines right down the middle over the apple logo it seems. The left and right sides are black as should be. But when the phone gets to my lock screen its fine just for a couple of seconds then the lines fade in? The touch screen is responsive and works well but the picture or background is glitched out with lines and squares.
Almost like I have clean working background but these lines fade in at the front? Any idea what component it might be that's giving me this problem? Everything worked fine before, it was just the battery that was giving me problems.
좋은 질문 입니까?
댓글 1개
Update: I read a couple other similar problems here and tried reseating the connectors and fully charging the phone. But after every reassembly the lines are back. Does anyone know of pictures or videos of how the connectors should look seated correctly? Or what damage would look like?
easy 의
