Wifi on my Samsung s duos is not working
When I on the Wifi, it goes into light green mode and does not come into complete green mode[Which is wifi adapter is failing]
Any suggestions on this.
Tried factory re-set but still the same.
좋은 질문입니까?
좋은 질문입니까?
Dear All,
Wi-Fi Freezing fault may occur due to 10% of Wi-Fi driver related issue and 90% of WiFi hardware fault,
Simply you can use hot air flow to U204 module and check whether it's functioning back to normal
other wise you will have to repalce new U204 Wi-FI + BT module
Here you can find parts for repair
Note : BGA reworking skills required to replace WiFi module
Hope you will be able to fix the fault your self.
Cheers!
이 답변이 도움이 되었나요?
이 답변이 도움이 되었나요?
dail*#*#526#*#* on your phone keypad this will show a message driver software sucessfully installed than try to turn on wifi this will turn no easily
이 답변이 도움이 되었나요?
It's not working.. can u please suggest me any other solution. .
it's not working ...... can u plz give another way to solve this problem ...
It is not working and can you please any other way to solve this problem
when we on the wifi the siginal ra not displayed on the screen what we should do for that
이 답변이 도움이 되었나요?
is it your own WiFi signal if it is, is it been set with a password for protection preventing other users connection to your signal?
Usually if it's able to pick up the wi-fi network but does not want's to connect is usually with the secuirity settings. you can try by deleating that as you defalt network and the se-activate it (try to reconnect to it) the default proiblem is usually the security settings.
이 답변이 도움이 되었나요?
the same problem occurs on not protected wifi..
Try. *#0011# > Menu key > Select Wifi > Select Power save button Off
Thanks
이 답변이 도움이 되었나요?
Tried this but not working
you should heating wifi and bluetooth ic and reboiling it or change it
이 답변이 도움이 되었나요?
My s duos i droped it in water then i put it in rice for a few days then i turn it back on everything worked except wifi and it was on low green. Before the water incident it was perfectly fine
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 78,435
댓글 6개
i hav the same problm,,wt can i do nw,i tried so many times its nt workinngggg
sr534223 의
mi wifi no funciona se daño solo me funciona con paquetes de datos
y eso no megusta por que es demasiado lento
leonardo 의
My WiFi connection is on but connecting any network does not connect and shows saved &secured
Ravi Kiran 의
My wifi Didn't even turned on.
Super Star 의
mobile does not support jiofi hotspot after connecting it show saved and secured but nothing work on it. plz help me why this is happening
Harshit Mahagaye 의
댓글 1개 더보기
