ipad air 2 Ram question
hello i have a question about the Ram in ipad air 2.
which is better two chip 1GB = 2GB or 2GB in a single chip?
which is faster or better, in general?
Thank you
좋은 질문 입니까?
Thank you
좋은 질문 입니까?
2 x 1GB Chips, as this way they run in dual channel, thus slightly faster.
해당 답변은 도움이 되었습니까?
True, if and only if:
The DRAM controller supports dual channel interleaving AND
The two chips each support the full data-bus width desired AND
The PCB design has the room necessary to support the larger trace count and DRAM package size.
For example, if the system data-bus width is x16 and 2GB is desired, the design could be accomplished with:
1) One "rank" or "channel" of two 1Gx8 chips (1GB per chip); or,
2) One "rank" or "channel" of one 1Gx16 chip (2GB); or,
3) Two "ranks" or "channels" or two 512Mx16 chips (1GB per chip).
The first two implementations are the same performance; only #3 is any faster!
Hope this helps!
Ah ok, I see, thanks for the info!
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 376
