주요 콘텐츠로 건너뛰기
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
31 질문 전체 보기
Camera fires automatically after cranking the lever.
I just picked up my camera after 2 weeks of not using it. I cranked the lever to take a picture and it fired automatically. Also, the light meter/on switch was off. I tried a couple more times and it kept firing automatically at the end of the crank.
I am living abroad right now with limited film and no known resources for film camera repair. Please help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
The Canon AE-1 uses a combo magnet/electromagnet to hold the shutter in the charged position.
This magnet is deactivated by a small electrical charge (electromagnet) which creates a canceling effect on the magnet causing it to let loose the bar which then allows the shutter to fire.
If something is in-between the magnet and the bar it can prevent the magnet from holding the bar causing it to release after you have wound the shutter charging/film advancement lever.
If you are careful you could try accessing via the bottom cover the shutter magnet/electromagnet and with a moistened strip of paper with reagent quality Isopropyl alcohol 85% or better, wipe the surfaces. If the magnet still won't hold you will need a new unit which will require getting to a camera repair shop.
Look online here: Canon
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
There is a magnet that grabs hold of a small metal piece when you $!^& it. You an easily see it when you open the bottom. Remove the plastic gaurd by pulling it away from the copper. $!^& the lever and when it releases hold the metalic piece to the magnet to try to remagnetize it. Worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you so much this saved me so much money at a repiar shop.
THANK YOU SO MUCHHHH!!! Currently have a half exposed roll of porta400 in mine and this just saved the roll! Had a tiny piece of the metal on one of the contacts!
댓글 달기
It could also be the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Grace 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 46
30일 전: 202
전체 시간: 15,608
