주요 콘텐츠로 건너뛰기
Sprint, U.S. Cellular, and Alltell CDMA version of the HTC Touch Pro (RAPH800).
1 질문 전체 보기
How to tell if it's CDMA or GSM version from outside?
I understand that this phone comes in both GSM and CDMA versions, and supposedly (Verizon?) which have both CDMA and GSM built in.
If so, is there a way to tell which version of the phone it is without opening the case?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
가장 유용한 답변
Actually there are quite a few different versions of the Touch Pro (HTC Raphael). The Verizon version (Raphael 500) does not have global capability, CDMA only. In addition, the phone has a different exterior than others, a different keyboard layout, as well as 96mb less ram to run applications on the phone whereas all other versions, such as the Sprint (Raphael 800) and AT&T Fuze have 288mb of ram.
There's quite a lot of information on these phones at the XDA-Developer's wiki so here's the link: http://bit.ly/bPnhez.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+ nice answer
댓글 달기
If you have the Verizon (CDMA) version, there is a Verizon logo instead of an htc logo.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
as a owner of a Verizon HTC Touch Pro 2 it is a global phone and you have the ability to switch between cdma or gsm. I have unlocked my phone simply by calling verizon customer service and speaking with the travel/overseas department. they gave me the unlock code so that i may insert any sim card into the device and switch to gsm. i have tried this locally with a t-mobile and att sim. it also worked overseas with a vodafone sim.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Can you update your answer to include unlock instructions? That'd be a good resource
댓글 달기
The Touch Pro and the Touch Pro 2 are totally different phones. The Verizon Touch Pro is NOT Global capable. Only the Touch Pro 2 has that Global capability.
Reference:
http://www.phonescoop.com/phones/phone.p...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dgreene 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 3,286
