주요 콘텐츠로 건너뛰기
17" Acer LCD monitor introduced in 2006 with a screen resolution of 1280 x 1024 @ 60HZ and manufacturer's item code AL1714CB-8.
7 질문 전체 보기
Why will my monitor not power up?
When I try to turn my monitor on, nothing happens. I've made sure it's plugged in, but it still won't turn on.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
The power button becomes non-functional on my AL1912 ... note similar model number. I fixit it about once a year like this Press and Hold these three buttons on the lower control panel:
> (right arrow) + Menu + Power
When the power comes on you are done.
Consider this me paying it forward. You can skip all the heroics below now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hit the power button which is located below the screen of the monitor. The green light should appear If monitor is working properly. If no light appears, this indicate that you need to replace power supply board.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Dustin Germain 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 337
