주요 콘텐츠로 건너뛰기
The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
Why isn't my printer turning on?
The front facing power light is not turning on, even when my printer is plugged in and the switch is on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
This could be an issue with your power supply, or it could be the motherboard. Once the supply is plugged in check to see if the blue light is on on your power supply. If the light does not light up please refer to the power supply replacement guide.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Make sure you have the power flipped to the right voltage for your area.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
valerie boyer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 525
