Can you fix chargeing ports on the htc one m8
My HTC one m8 will not charge because the charging port
좋은 질문 입니까?
좋은 질문 입니까?
If you are sure it's the problem of charging port, just replace with a good one.
Replacement guide: https://www.youtube.com/watch?v=QQjJkkok...
해당 답변은 도움이 되었습니까?
Can u point me in the direction to a good one I bought a cheap one off eBay and it still had a shortage
Unifix Direct sells a whole kit to replace the micro USB board for either the single pin or double pin version (check this beforehand as I messed up and used the double pin in a phone meant for the single pin). Not only do you get useful tools to open the phone but the part works well and comes in an anti-static bag (and already has EMI shielding tape attached to the ribbon cable except for the part that goes int the ZIF connector)
해당 답변은 도움이 되었습니까?
I just noticed I have a single pin and I bought the double. Did it affect your phone? I'm debating putting it in.
@Brian Gillespie It did impact my phone as I noticed it made the screen so dark that it was almost impossible to see anything on it, forcing me to buy a single pin part and redo the whole install to avoid the issue. I can't remember if Unifix Direct offers a single pin kit as well since the replacement part I got may be wearing out after less than a year, which is unfortunate as I broke the plastic ZIF connector piece for that board (didn't seem to impact performance)
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 17,760
