주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
MBP Retina is not turning on after water-damage
Hi
i have a MBP Retia with a water damage. Everything is now dry an cleaned.
As you probably guessed, the MB doesn't turn on, if the power button ist pressed.
A PC-repair-shop siad, it is probably the logicbaord. But befor i buy a new logicbaord, i want to be sure, that's realy the problem. i heard that it's often something else.
when i connect the magsafe-powercoard it turns orange after 3 seconds. So this means it is loading, right?
So i tryed to bypass the powerbutton by connecting the 2 pins on the logicbaord-keyboard-connector.
When i do this, the LED on the magsafe turns green for three seconds and then back orane. nothing else happens.
what does this mean? the logicbaord can't be completly dead, right?
can you help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The magsafe turning orange means the charging chain is good. The keyboard ribbon must be disconnected to jump the machine... did you do that?
If the machine still won't start (does nothing at all) then there are multiple problems with logic board components and/or circuitry.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
3 댓글:
Hi
this mornig, magsafe is green, if plugged if. is this good?
i didn't know this with the keybaord ribbon. unplugged it now but no difference. the green led goes off for a moment and then back on.
Is there a way to narrow down the problem?
Only with your eyeball and a magnifying glass. Look for corrosion (discolored circuit leads, burn marks or swollen components).
ok, sounds like a job for a professional repair-shop.
THX
댓글 달기
Look up BitPC Repair on Ebay. He has worked on my tough repairs in the past and fixed about 99% of them. Charges $120 for the repair. If you are like me you probably want to try to fix it yourself. The green light and the amber light are a good sign so its getting power and charging the battery. Trying it with a good known working keyboard for that model would be a good start. Although if the keyboard is affected it would start as soon as you plug in your magsafe adapter. I have one right now that had water damage and may need a new topcase, AHT is giving me an error for a temp sensor and the fan is spinning at the max level. I like doing my research to an extent, but when it gets over my head I send it off to the experts.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 714
