Why can't I factory reset my Alcatel One Touch Idol X 6040A?
I decided to put a pattern password on my phone and forgot the pattern. As I was going to factory reset it by Power + Volume up all it does is turn my phone on and off.
좋은 질문 입니까?
좋은 질문 입니까?
1.Power up the phone by pressing the Volume UP + Volume DOWN keys together + Power key.
The device will enumerate with different BOOT OPTIONS.
2.Use the Volume DOWN Key to scroll and Volume UP Key to SELECT.
3.Select Recovery.
The device will start up with the logo and power up to a little Android man with Exclamation mark.
4.Press the Volume UP and Volume DOWN Key together at this screen.
The device will display BLUE Text on a Black background.
5.Use the Volume DOWN Key to scroll DOWN and the Power Key to SELECT the option desired . In this case , press the Volume DOWN key till the Wipe data / factory reset is selected and press the Power key to confirm the selection.
6.Use the Volume DOWN key again to select YES – delete all user data and press the PWR key to CONFIRM.
The device will then start performing the Factory Data Reset.
7.Once the Formatting is complete , press the Power key to confirm a REBOOT.
The message rebooting is displayed on the phone. The device will reboot and start the normal power up sequence .
해당 답변은 도움이 되었습니까?
This is the most accurate information I have found yet.
Fire 🔥 I made an account just to say how helpful that was! Thanks BurnieG
you have to let go of the power button as soon as it turns on.. hold the volume up and down til u see the reboot screen.
해당 답변은 도움이 되었습니까?
THANK YOU!!!!!! you were the only person I've found that helped!! THANK YOU!!!!!
Only one that worked!!!
What if it doesn't even show the reboot menu
Every time I try it my phone always says no command but doesn’t show all of those options only no command
What do I do?!
holdthe volume up button and power botton till the phone buzzes twice. then let go. will go to boot screen
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 8
30일 전: 31
전체 시간: 29,602
