주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2013년 7월에 출시된 경제적인 Samsung Galaxy S4 버전입니다.
110 질문 전체 보기
Are the LCD connections the same between the S4 & S4 Mini?
I am just wondering if the LCD connection is the same between the Galaxy S4 Mini and the Galaxy S4?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 2개
선택된 해법
No,
The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels.
Regards.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
A couple of questions, if you don´t mind.
You mention that "The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels", does that mean that the connectors are different or that it will work with less resolution?
I have an S4 with a broken lcd. I want to enable usb debugging on it, so I can see the screen on my pc while the replacement screen arrives.
I also have an S4 mini and I was wondering what would happen if I plugged the S4 mini lcd in the s4 connector. Can I damage the working S4 mini screen?
I only need to see the settings screen.
Thanks!
의견 추가하세요
No,
the connectors are of similar type, but they are not the same. The s4 mini connector is a bit longer, so it won't fit. It also has more pins.
I don't know if they are electrically compatible. Theoretically, if you somehow connected the right pins, for example by a custom made connector cable .. it might work, or break something.
Regards,
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Kelby 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 886
