주요 콘텐츠로 건너뛰기
This 2012 K410 model of the Lenovo K Series desktop features a three speed power control switch and a 3rd generation Intel Core processor. Its high preformance graphics capabilities make it an excellent choice for gaming.
12 질문 전체 보기
Why isn't there anything showing on my monitor?
When I try to use my computer, there is no picture on my monitor. It's like I can't get it to wake up. My computer is totally unresponsive to the keyboard and mouse and stays black no matter what I do. What's wrong with it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Check to see if the monitor has been turned on; if not, press the Power button.
Check to see if the monitor power cord is loose; if so, plug the power cord
securely into the monitor.
Check to see if the signal cable to the monitor is securely connected to the
connector on the computer graphics card; if not, shut down the computer
then connect the signal cable of the monitor securely to the connector on the
computer graphics card.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First of all you need to make sure about cables and connectors. are they properly connected. if they are connected properly but still you are having same problem then it might be problem with your monitor or graphics.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Emily Kaplan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 590
