Is it possible to upgrade HD drive to SSD drive?
MacBook 13" Unibody fall 2008.
I would like to upgrade my HD to a SSD drive as they say its much faster. Is this possible with my computer, I cant find it on your website.
좋은 질문 입니까?
좋은 질문 입니까?
Yes, you can upgrade the HD for a SSD. You'll need to make sure the unit you get is SATA II (3.0 Gb/s).
You may want to consider going with a cheaper option. How about going with a SSHD instead. These hybrid drives have a SSD for the speed and offer a traditional HD for the deep storage. Here's the Seagate unit: Seagate Laptop SSHD. The 9.5 mm unit is what you need. These drives also have auto-SATA sensing so it will work without any problems.
I do recommend you make sure your systems firmware is up to date as well here before you do any alterations. Here's the Apple TN on how to check and update: EFI and SMC firmware updates for Intel-based Macs
해당 답변은 도움이 되었습니까?
Click on the blue links to get more info
There is no MBP 13" fall 08 - first MPB 13" was late 09.
You have a MacBook Unibody late 08. As long as the SSD form fits and the SATA is 3GB/s it will work.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
it say mbp "13 fall 08 in my computer?
Where in your computer? Doesn't affect the answer.
on the about this comp
Can you give us the last four digits of the serial number so we can verify the model. Without knowing what you have limits what we can offer you for an answer here.
the last four digits are l8qr
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 346
댓글 3개
MacBook 13" "Core 2 Duo" 2.0 GHz (Unibody)
Dan 의
it says on the about -
MacBook (13-tums, Unibody, fall 2008)
2 GHz Intel Core 2 Duo
8 GB 1067 MHz DDR3
NVIDIA GeForce 9400M 256 MB
lucho 의
Yes, click on the Blue link I put above it will open up EveryMac's web sites listing of your system.
Dan 의
