주요 콘텐츠로 건너뛰기
Released June 2011, identified by model number MB870
10 질문 전체 보기
How should I remove a stripped screw?
When opening up my device while following one of your repair guides, one of the screws inside the device became stripped. How could I safely remove that screw from my phone to continue with the repair process?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
There is a guide on ifixit found here
During the initial breakdown, we also stripped several screws.We found that using elastics was ineffective as the driver heads were small enough to just puncture the elastic. We found that using a rotary tool to create a slit for a flat head screw driver worked best. However this is a little risky and should only be done as a last resort.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Depending on the location of the screw, you may be able to grind the screw head completely off. Then once the part you are removing is completely out, you should have enough of a screw protrusion to be able to grip it with small pliers and turn it until it comes out. Again, this is quite advanced so you would have to be comfortable with working with a Dremel tool.
You can also get kits at home depot for removing stripped screws. There are ones that come with putty that you can apply to the screw head and then when it starts to harden you can push your screw driver into it to create an imprint. Once it dries the screw should come out reasonably easily.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alec Riendeau 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,245
