I do not know the Phoenix BIOS password
There has never been a password seto n this unit. I want to chagne the boot up process and I am being asked for a bios password. None of the defaults are working.
좋은 질문 입니까?
좋은 질문 입니까?
There is a coin batter y inside the tough book. remove this and hold the power button in for 60 seconds to discharge the capacitors, the cmos memory should be cleared.
remove the RTC battery and the main battery, then unplug you computer and depress the power button for 30-60 seconds this should reset the cmos there are also posts locates at ic 61, 63 shorting these will perform a cmos reset as well.
해당 답변은 도움이 되었습니까?
Hello,
i don't know how to find ic 61,63..
removing the cmos battery don't help..
please,please help me
Unfortunately this didn't clear the BIOS password for me.
Did you hold the power button down while jumping the pins with the battery out?
get a dos and debug
do the 70/71 port magic
to clear CMOS
google for detail
code:
0B12:0100 mov cx, ff
0B12:0103 mov al, cl
0B12:0105 out 70, al
0B12:0107 xor al,al
0B12:0109 out 71, al
0B12:010B loop 103
0B12:010D int 3
0B12:010E int 3
해당 답변은 도움이 되었습니까?
Hi, it worked in my panasonic CF-30 very well,, thanks
My bios password is removed easy
해당 답변은 도움이 되었습니까?
How did you do it? Please help!
Here is an article talks about how to reset BIOS password, you can read it in
해당 답변은 도움이 되었습니까?
I hawe panasonic CF-19 , how to remowe bios password ? remowe battery not help :(
Please tell me how to remowe bios password ... bmw@hotmail.lt
해당 답변은 도움이 되었습니까?
Erase the EEPROM /Bios Chip. and Flash it with fresh bios file. You have to need EEPROM programmer and 8 pin Socket also.
i need the dump for cf-31 i have the programer
I have the same problem of Hakeris, I did any standard procedure (remove cmos battery and main battery,push power switch,press F2 etc..) but the bios password persist.
there are 2 battery inside ? RTC e CMOS battery are the same ?
many thanks
해당 답변은 도움이 되었습니까?
Panasonic cf 30 forget BIOS password try all above option but still problem is there
해당 답변은 도움이 되었습니까?
CF-SX2 I’m forgote password bios
help me please!!!
해당 답변은 도움이 되었습니까?
https://www.youtube.com/watch?v=Uos3iHOg...
REMOVE BIOS PASSWORD PANASONIC LAPTOP
해당 답변은 도움이 되었습니까?
unlock all panasonic BIOS password
if i can not unlock , i will Refund 1000%
Last post was spam, and the video is spam. I have a Toughbook CF-30 MK3. It’s locked with BIOS password and I have tried everything, removing battery etc etc. All the online suggestions I have found so far have failed. Can anyone please advise of any other ideas? I have a dump if that helps. Thanks
해당 답변은 도움이 되었습니까?
just did it on my cf-31 mk1.
Panasonic told me, to send it to panasonic UK.
The’ll have to change my motherboard ! pha ! Just did it today !
But ONLY if the mashine can boot up in the running OS !
otherwise, i can’t do that
Just mail me
해당 답변은 도움이 되었습니까?
24 시간 전: 7
7일 전: 35
30일 전: 111
전체 시간: 49,687
3 Comments
tengo una panasonic cf-31 quiero quitar el pass pero ocupo un bin dumpeado si alguien lo tiene por fas
noel 의
hard_ware2003 의
unlock all panasonic laptop , my skype : haisung4344
hard_ware2003 의
