Trackpad cursor not moving
I'm working on a macbook pro, and I can move the black cursor when I have a usb mouse plugged in, the trackpad won't respond when I disconnect it, but when I try to click, that works. What could be the issue?
좋은 질문 입니까?
좋은 질문 입니까?
There could be liquid or other physical damage to a part of the trackpad cable or connector. Since there's been a couple of iterations of the track pad without a more specific ID (yours covers 7 devices over 3 years) I can't be more specific.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
If their was liquid damage wouldn't the clicker not work? I replaced the trackpad cable and the trackpad itelf, and same problem, I can't move the cursor, but it can click if I use a usb mouse to move the cursor
I do not know the schematics of the cable but not all the cable wires run "the clicker" that's why it could be a bad cable, or a cable that is not in far enough or may be cocked to one side. Also one side of the connector could be damaged. in a different matter a user had a wireless card that he removed and could not get to work. After trying a different card he looked and found a bent pin on the card slot. He managed to correct the pin without breaking it off and the problem was solved.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,275
