이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
liarliar, just like your other question:"Where did you measure for continuity? Why did you check for continuity? You should not have continuity between the battery tips. The more information you can give, the greater the likelihood to get a valid answer. "
oldturkey03 의
