모델 번호 A1347로 식별되는 Mac mini의 유니바디 알루미늄 세대입니다 - Mid 2010부터 현재 판매되는 Late 2014 모델.
727 질문 전체 보기
Upgraded to 640GB WD Scorpio and now Flashes & Beeps
I just installed a bigger hdd and now the Mac flashes it's front light and beeps every 5 seconds
I followed the tear down and to get to the hdd and swaped out for the bigger one and reassembled
I was hoping I could just format the hdd once I turned it on but I guess that's not the case
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
No it just flashes and beeps continusly... I'll google the beeps codes and see what I can find out
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
Does it flash the front LED 6 times? If so, according to Apple, the processor is unusable. How this happened? I have no idea. Did you damage the logic board in any way? Try reseating the RAM (improbable). What I would do if I were you is put back the original HDD, test if it works, if it doesn't then take it to the apple store and leave no marks on the mac mini, return, get a new one. If it does work that means its the HDD is broken.. although... it would never be reported as a bad CPU... anyway it would be highly confusing if it DID work with the old HDD.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Okay turns out i just didn't put the ram back in properly...
So the drive works and now have 640GB HDD, infact I'm just finishing up installing
iLife on the Mini. For those of u wondering the beeps was one beep + flash in every 5 seconds so it was bad CPU just reseat ram
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Mark 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,027
