주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
질문 마감됨
Keyboard and Track Pad random works
HI everybody,
Yesterday the keyboard and the trackpad of my MBA 2013 stopped working simultaneously.
Today, keyboard and the trackpad has worked only for 10 minutes. I only could do clicks with the trackpad but the keyword worked fine.
Could you please shed some light here? As I understand, the keyboard and trackpad has separate connectors.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
The machine should run OK with the battery disconnected.
Here's how to replace the battery: MacBook Air 13" Mid 2013 배터리 교체
Also try using an external USB keyboard and mouse to help isolate the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
This may be caused by a swelling battery - if so it is a dangerous condition and needs to be looked into or eliminated as the cause right away - Li-Ion batteries in this condition are dangerous and could start a fire.
It has been know to happen that a swelling battery presses on, can pinch or otherwise short the trackpad cable.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
how can I check if it a battery problem?, Also can I disconect the battery and use MBA only with the AC?
You have to look at the battery with a Mark I eyeball - swelling should be evident at the edges.
댓글 달기
Thanks everybody.
I am trying to buy a screwdriver in order to check it. I'll keep you updated
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 145
