5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2996 질문 전체 보기
Battery doesn't connected and turn off after about one minute?
My iphone 4s got serious water damage.
I've replaced the battery and connector dock after washed it out with isopropyl 99%.
It can turns on but then stopped and then rebooted automatically.
I have tried to figure it out, and I realized that It has same problem even without the battery. and every other parts have no problem.
What should I do for now?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
가장 유용한 답변
Great job on skipping the rice and taking care of your water damage properly.
This problem is going to be a disconnect between the battery middle pins--temp and gas gauge lines. The board can't talk to the battery so it is shutting off. Sometimes this is battery, but most likely you have corrosion/damage to the tiny components near the battery connector, or the battery connector itself.
Repairable with micro soldering.
Show us a bright picture of your board
Jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank you so much jessa,
http://imgur.com/SEdRcqp
Please have a look this image, I tried to get a better image, looks like it's the best.
I've washed it out every corrosion I can see.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Isaac 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 55
