주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
질문 마감됨
Shift key always on - keyboard replacement didn't work
I just replaced the keyboard in a 2011 MacBook Air due to the shift key always being enabled but that didn't solve the problem.
  • Shift key shows as always pressed
  • Replacing the whole keyboard with a new one didn't help
  • Same problem in single-user mode and the terminal in recovery boot
  • No visible liquid damage
  • USB keyboard works fine
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It turned out to be the chip/daughterboard on the Trackpad.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Too me, this sounds like you may need to have a look under the keyboard itself. Follow this guide to do this:
https://www.youtube.com/watch?v=LCT-CldP...
The above link may work, please accept this answer if it has helped you
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
First line: "I just replaced the keyboard..." = the whole keyboard has been physically replaced with a new one.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 176
