주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
251 질문 전체 보기
Charging for few minutes but won't turn on.
Hi.
My brother accidentaly got wet my DSL. It won't turn on. The LED turns green for 2-3 seconds, but DS doesn't do anything. When I set it to charge it's charging for 5-10 minutes and then the LED stops glowing. I've bought new battery, but it's not working.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 2개
가장 유용한 답변
hi
sounds like your motherboard has blown, this can be repaired but it's pretty tricky to do this - you'd be better off buying a second hand motherboard and replacing it
note though that depending on how much water got in there, it may have also waterlogged the screens as well - if that's the case then you'd be better off buying another second hand ds - they're cheap enough on ebay these days
hope that helps
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks! Yeah, they are pretty cheap. :)
의견 추가하세요
Check the F2 fuse to see if its blown
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Denis Bogdan 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 167
