주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
My Nexus 5 has water damage apparently. Can it be repaired?
I am in Brazil for the foreseeable future and have managed to break my phone... and prices are very steep here to just go buy another one!
I took it to a repair shop in a local favela... my friend knew the owner and so I could trust him with my device. When I went to pick it up he said that the 'placa' had begun to corrode due to water exposure... which I believe is something like a motherboard.
I am not sure how any water got in to the device... I have had it for about 6 months and not once have I dropped it in a puddle or taken it out in the rain etc.
It started acting strange..lagging up and resetting itself. Then it started resetting itself constantly just getting to the Google logo and then resetting again without any way to stop it.
Now, I believe the battery has just died so it is just a paper weight at the moment.
Any suggestions? Can I buy spare parts? Or should I sell for 70 reias (basically 25 dollars)?
Thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Open the phone and clean with 99%+ iso alcohol, check components for corrosion and replace if necessary.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Can I use Isopropyl alcohol to clean out the LCD screen? I cleaned out the circuit boards but there seems to be water stuck inside the screen which is making it darker.
댓글 달기
Yes it can be repaired I my self had taken mine all apart ,piece by piece let it dry, but I also did shut it off quickly as possibleofcourse and cleaned it with rubbing alcohol. I put it back together turned it on and it was working even better I thought lol.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,058
