주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
질문 마감됨
I took apart my phone and now the wifi dosnt work
i took apart my phone to fix get rid of the power button and now the wifi dose not work. seriously need help all i have is 1g a month for web and im constantly on my phone
http://youtu.be/3Glllc7bEJs
i used this video as a reference
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
also the blue tooth is having the same problem could this be connected to the wifi problem?
댓글 달기
답변 2개
Hi Devin,
It could be multiple things, but if your wifi worked before the fix it might not be as bad as it can get (wifi chip)
First thing to do is to go over the connector on the bottom leading to the docking. These things sometimes break when you disconnect them. It does not happen often with Samsung phones but it can still happen.
The cable we are talking about is this one:
It should be on the right side of the back, make sure this cable is in order and make sure the connection is solid on the docking part.
If this is all ok it might be software related but we can get into that part later.
Let us know!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
hi kevin thank you so much for replying it means alot. i looked over the cord it looks like its still in mint condition and is docked correctly. so it must be a software problem. it might be because i accidentally started the custom os option when you start the phone up by plugging it in and holding down the down volume key and the home button but i took out the battery quickly and later factory defaulted my phone just a little added info. but if it is the soft ware what might it be and how hard do you think it will be to fix?
댓글 달기
if your bluetooth is also not working after you have attempted a repair then i'm gonna guess you have damaged the wifi/bluetooth IC.
http://blog.brokenlcds.com/wp-content/up...
and
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
if it is that how could i tell if thats true and how hard if possible would it be to fix?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 143
