주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Wifi No Hardware Installed
I am not getting wifi. I had a no hardware installed message, before i reinstalled OS X. Now i don't even have a wifi option. Bluetooth and I sight works fine.
What I've tried so far. Ive replaced the wifi card. Same result
Next I ordere a used cable and tried that without removing the display and attaching one end of the cable to the i sight camera. This gave me no wifi or bluetooth (or i sight because i didn't hook that end up ) I thought this cable may be defective so i ordered another one. Same result. Do i potentially have three bad cables, or do the two "new" ones have to bee connected to i sight in order for wifi and bluetooth to work. Thank you in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Check the card connector. Someone here with similar problems found out that they had bent a pin on the connector (they too tried multiple cards). Fortunately they were able to straighten the pin without breaking it off.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I inspected both sides of the connector they look good.
Did you use a mirror and a light and look inside the slot?
댓글 달기
귀하의 답변을 추가하세요
Kent 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,079
