주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
PowerPC G5 프로세서를 사용하는 iMac G5는 2004년에 처음 출시되었습니다.
593 질문 전체 보기
Computer recognizes drive but I can't erase or initialize
Hello, I recently purchased a 3 TB Toshiba internal hard drive that I want to use as a second drive in my Duel Mac 2Ghz PowerPC G5. The computer recognizes the drive but I cannot erase or initialize the drive. I'm running Mac OS 10.4.11. Any help would be great, thanks!
Tym
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
More than likely you are having a SATA problem. The HD you recently purchased may promise to be backward compatible or automagically self limiting (and should be) but I belive it's not working.
Your ID fits 5 different versions of the G5 box, but all use SATA I HD's.
You may be able to manually set the SATA speed of the drive. If not you may want to try a different SATA cable or need to find a different drive.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I think the problem is my computer uses ATA, not SATA, for the internal hard drives.
의견 추가하세요
귀하의 답변을 추가하십시오
tymmac007 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 80
