주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3756 질문 전체 보기
질문 마감됨
The device will not turn on.
I ordered this phone off of Ebay thinking it was simply a bad battery. I replaced the battery and still cant get the phone to turn on. Both inside and out the phone is in impeccable condition. None of the 3 water damage indicators are "tripped". I have no idea where to start as far as troubleshooting goes so ANY help will be appreciated!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Also - quick update - I plugged the phone in for about an hour to see if it would turn on - it got warm but still would not turn on
의견 추가하세요
답변 1개
The phone can't turn on maybe caused by several reasons such as:
No power.
No screen.
Broken motherboard.
If it's no power, you should check all the parts relating to charging such as battery and charging port.
If it's no screen, you should replace the LCD screen.
If it's caused by broken motherboard, i suppose you have to give up.
The phone can't turn on, so we can't ensure it's troubled by one reason or two reason even all the reason.
First, if can, take your phone to repair service to test the motherboard. If it's fine, the phone still be worth to save.(Only my own suggestion.)
Then you can try the other good screen or change the charging port. Maybe all can be test on the repair shop.
Good luck to you!
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Okay so should I check stuff like the dock and the power button with say a multimeter or should I just buy the parts and see if they fix it?
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 108
