주요 콘텐츠로 건너뛰기
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
20 질문 전체 보기
Why isn't the keyboard dock working?
My transformer pad is connected but i cant use the keyboard because it won't pop up i can only use the 'e' and 'l'key. Also sometimes when i connect the keyboard dock the screen freezes and shuts off and wont turn back on again.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
I have the same problem. The "c" types in ";" the "x" types in "q" and the space bar doesnt wok. HELP ME
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
same problem. can someone help me pls
댓글 달기
Make sure you haven't downloaded any alternate keyboards. If you have, disable all but one. Other than that, that's the only thing that helped mine. K0101......
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The last couple that I have repaired have had weird keyboard faults and they both turned out to be poor seating in the edge connector under the keyboard. Pull off the four rubber feet and undo the screws. Take out the two visible ones underneath and the three under the silver tab directly beneath the touchpad. Unlock the ribbon edge connector and clean the ribbon contacts.
It may be as simple as that.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jennifer Hernandez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 14
전체 시간: 2,139
