주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1232 질문 전체 보기
dropped all works but the screen/touchscreen. Tried a new screen
Hi Rany. Your description sounds like the issue i have.
iPhone 5c dropped all works but the screen/touchscreen. Tried a new screen but no luck.
How can I check if its the backlight issue? (but lack of response from touchscreen makes me believe there is more to it)
Kind Regards
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개:
Before going crazy with diagnostics, try this, disconnect battery for a few moments and then reconnect it.
Actually cleaning and reseating fixed it for him.
댓글 달기
답변 1개
Hi Daniel,
So your phone doesn't show an image/or backlight AND touch is not working? Are you sure it is a drop, not liquid damage? Back light, image, and touch are 3 different functions with somewhat different "circuits" on the board. They may both be damaged, but more often it is just one of the 2. I'd start with the following:
- There are 3 screen connectors on the board. Clean them with a cotton swab dipped in 90%+ isopropyl alcohol. Then try reseating your screen and re-booting your iPhone (press & hold home + power buttons for ~12 seconds straight then restart your phone).
- If no change, remove the black film (very carefully) around those connectors on the board and look under a magnifying glass for missing/broken/part removed components.
- If you see nothing wrong, try a KNOWN GOOD display, something that you know for sure works on a different device. OR transfer your logic board to a known good phone. Let us know what you find out at this point.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 93
