주요 콘텐츠로 건너뛰기
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
Why won't my device turn on?
When I press the power button nothing happens.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
This may be a sign that your battery is depleted and needs to be charged, or you may have an old battery that requires replacement. Charge your laptop fully and see if it turns on, if not consider testing your battery's performance and replacing it.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
The problem might be located in your hard drive. There are a few probable causes for this including:
  • Your computer is bumped or jostled while it is running
  • The electric motor which allows the platter to spin fails due to bad bearings or other components
  • The filter on your air intake gets too clogged or the filter isn't working properly
  • Extreme heat while running causes the electronic circuit board to fail
  • There is a sudden power failure while the disk is writing
Try troubleshooting your hard drive for these possible causes and refer to the repair guide to help fix this issue.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The power jack may need to be replaced, or the AC Adapter may need to be replaced. Use a multimeter to confirm that the power output from the AC Adapter matches what you see on the multimeter. If it matches, the by process of elimination, you can move on to the next possible cause.
After removing the motherboard, examine the power jack solder points, and the internal power jack for damage to the center pin. If you confirm the solder points are loose or broken; or the female receptacle area of the power jack is damaged, then replace the power jack.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
justindistaso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 2,698
