주요 콘텐츠로 건너뛰기
The Lenovo Ideapad Y410p is 1.29 inches thick and weighs 5.5 pounds. The device is known for its Premium JBL® Speakers, NVIDIA® GeForce® Graphics, and Intelligent Touchpad. Model number: 59399853.
14 질문 전체 보기
Why won't the laptop power on?
When I plug in my laptop there is no power LED on either the laptop or the charger. However before I plug in the charger the light is on. Why does the charger light go out when I plug it in?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
When and how did this occur?
댓글 달기
답변 1개
가장 유용한 답변
i sounds like there may be a short in the dc jack or the mother board. id start by seeing if your dc jack is soldered to the mother board, attached to the board with plug in leads or on its own power board and looking in to replacing that first and going from there to suspecting the motherboard if the dc jack is on leads it can be easily tested with a volt meter. I would also test the ac adapter with a volt meter to be sure it putting out the proper voltage.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
if there is a short in the motherboard, is there anything that can be done ? the PC doesn't power on, just makes a strange clicking noise.
When I plug in my laptop there is no power LED on either the laptop or the charger. However before I plug in the charger the light is on. Why does the charger light go out when I plug it in? and i check it with volt meter
댓글 달기
귀하의 답변을 추가하세요
Keith Batryn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 808
