Repair guides for many brands of PC laptop (notebook) computer.
9951 질문 전체 보기
HORRIBLY slow download speeds in iTunes, Help!
I'm using a Windows laptop, (Windows 7). Had it for a couple years, runs fine.
Internet speed is normal, but im trying to restore various iPhones but the software for the updates and iTunes its self won't download.
It says around 120 hours remaining and then errors out. Help?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글:
and i have already restarted the computer, and uninstalled and reinstalled itunes.
의 답변
How are you connecting your system directly via Ethernet or WiFi? Do you have a second system which is working though your cable router?
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Take a look at your systems resources. Do you have at least 1/3 of the HD free? Have you tried defragmenting your HD? If your system is highly fragmented it can cause slow file transfers. You can also have a drive thats starting to fail as well.
Try connecting via direct Ethernet to your router, Is that any better?
What are your iPhones? You maybe able to download directly over the cellular network (check your service contract first! Some limit you on how much as well as how fast).
Don't forget your internet connection is not symmetrical (same data rate up & down) must are asymmetrical (very slow up and faster down). Why this is important is if you are saving to your iCloud account. Make sure you don't enable iTunes Match services until you've upgraded your iPhones.
Check your internet connection using this free app: Network Speed Test.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Austin Harris 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 46
지난 30일: 210
전체 시간: 25,249
