주요 콘텐츠로 건너뛰기
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 질문 전체 보기
Headphone always on / detected
Hi there,
I have a question regarding the Sony Xperia Z.
The Xperia Z seems to always notify me that it has a headphone connected while it has nothing in there.
The little flap/cover is broken off from the frame, wich is something i have to mention, so it does notify about the phone not being waterproof.
When i use SoundAbout and rearrange the sound output i can call and hear everything just fine. When i disable the app, i have to use the headphones with mic to be able to call or the phone will not use the earspeaker or bottom mic.
What i wonder is, even after a complete factory reset aswell as disconnecting the headphone jack from the motherboard, the phone still notifies about the headphones being plugged in when the phone boots into android.
What i would like to know is, can this be a motherboard sensor failure, or does this have to do with the fact that the flap is broken off too?
What i tried:
  • Factory Reset.
  • Jack unplugged on motherboard.
  • Playing music while having the jack plugged and then unplug while playing.
  • Force stop "Smart Connect", cleaning cache and data.
I cannot seem to find what the cause is, im beginning to think that either some circuit is messed up on the motherboard itself or that the flap/cover is the cause.
I hope somebody can help me out here.
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 2개
Nobody with an idea?
Why my phone has no sound
댓글 달기
답변 10개
가장 유용한 답변
I have these prob too I can't fix it but I find to way to solve that temporarily
Just do this
Volume up everything ringing alarm media
Go to radio app and turn to sound to loud speaker
After that u will hear sound of radio
After close radio app using square button. On navigation pane under the display
I think This will work for u
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
This don't work for me but solved using SoundAbout or AudioSwitch
I cannot believe this actually worked. Been a couple of years mine's been in a drawer with this issue, and the radio setting was the culprit. Had to uninstall Soundabout to get it back to normal.
Oh my god,it's so unbelievable,volume up music alarm rington, then put something like a pen,go to radio,change from headset to loud speaker, remove the pen and close the radio,your phone is ready my friends
댓글 달기
It's not caused by broken off cover flap and the cover flap can be repalced by http://www.witrigs.com/replacement-parts...
As for the headphone, have you tired change a pair of headphones? And before you repairing the motherboard, what other you can try is replace the headphone jack.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Kevin,
The fault coming from your Headphone connector, Here you can fine the guide for Headphone replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
the same what happend to me, bro to clean inside the jack with somthing small like a pen or something else then insert your headphone it should work ;)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem. Insuflate sevetal times into the jack solved the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I too have the same problem with my Xperia zr. I am not even able to make Soundabout work because even if I choose speakers in that app, music still plays only on the headphone. I can make calls only by connecting headphones or by talking on the loudspeaker. How to deal with the problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Soundabout helped me in this case. I to had the same problem. Guess it's the prob with the hardware. The audio is automatically routed to headphones.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi please do not restore your phone like I did you will regret it.... Here is the solutiin.....
Settings>>sounds and notification>> App notification>>all and the ln scroll down and select headset then press and hold this icon⚠ then disable app.....ever since my phone is perfectly fine :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had same issue with Xperia SL.
I just tried to insert the headphone jack in and out few times, in a cross position and it worked
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The early generations of Sonys Xperia Z line, Z and Z1 have extremely unreliable headphone connectors. During my time as a professional service technician this was one of the most common problems on these phones. You will have to replace the headphone connector.
The repair is quite hard if you have not worked with a hot air gun before. If you know your way around one, it is quite easy as the phone is very modular and comes apart easy once you have removed the back cover.
Guide; Sony Xperia Z Headphone Jack Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 16
전체 시간: 24,299
