주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1232 질문 전체 보기
iPhone won't charge after battery and dock replacement.
My iPhone 5c was having some major battery issues. I ordered a new battery and put it in. It worked fine, until I tried to charge it. My iPhone wouldn't charge or even vibrate. I've tried in the computer, the wall, different cords..I even tried putting in the old battery. It didn't even work when inserting the old battery. (Also my home button wasn't being recognized and my bottom speaker wasn't working.) I figured I had messed up something with the lightning port and that might be the issue. After replacing the dock connector with a new one, the iPhone still doesn't charge (or the home button doesn't work). I really need help with this one!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
The reason why you old battery doesn't work is likely because it's dead flat, there is a small chance that the charge port you purchased is faulty as well as your original port but it's unlikely. It's is more likely that the charge IC on the motherboard is busted in some way. The process of replacing, repairing or even diagnosing this is pretty intricate, If you want to look into it further, check out http://gsmforum.com/ as these guys really know their stuff. It would be infinitely easier to just put your original parts back in and take it to apple to get a refurb replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
McKay Fackrell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 611
