주요 콘텐츠로 건너뛰기
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2 질문 전체 보기
질문 마감됨
How do I get my pump to stop making bubbles?
My pump works but it makes bubbles.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
This is most likely due to a broken impeller, and the impeller assembly will need to be replaced. It could also be due to air locked in the pump housing, which is most likely due to the pump not be fully submersed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 630
