주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3017 질문 전체 보기
pry damage solder a wire or replace component
hello all.
i have a iPhone 4s from a customer, it has a some pry damage (he tried to place a new screen)
now i replaced some 0603 and 0402 components.
but this little black block i don't know.
is it possible to solder a wire on the pads ?
or do i have to replace the component, but what component is this ?
thanks in advance
Update
anyone that can tell me if i need to solder a wire or not
thank you
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
roy, we can not see what you see. Post a couple of images with your question. Adding images to an existing question Show us the components you replaced as well as the "little black block"
thanks oldturkey, seems because i was on dutch i couldnt edit my post or place pictures.
thanks
hey Oldturkey,
i posted the pictures, can you tell me if i can solder a wire across or if i need to resolder the component
thanks
can someone tell me
or if you need a differnt picture also tell me
thanks in advance
I never advocate jumpers. I figured the Apple engineers had a plan with all those parts. Replace them with proper components.It is a Zener diode and check st3v3w's schematic for the proper values.
1에 댓글 더 나타내기
의견 추가하세요
답변 1개
선택된 해법
I can't say whether or not it is safe to jump them with a wire but the part is called DZ30 and it has to do with the head phone jack . i belive it has something to do with an external mic.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
roy 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 178
