The Wintec Filemate Clear is an Android tablet with a 7 inch screen and 1.2 GHz processor. The tablet features 2 cameras, 2 megapixel rear camera and a VGA front facing camera.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Your device may be receiving poor ventilation, try removing the back plate to allow proper ventilation. Your device could have a faulty battery and need to be replaced. Your device could have a faulty and drive and may be overheating due to malfunctioning.
Like mentioned above, there might be poor ventilation or dust buildup inside the tablet. . It could also be a hardware issue; if the motherboard or CPU is faulty, it may mean you need to replace them. Try to locate exactly where the heat is coming from and work from there.
Akiyah 의
