installed wrong startup disc, wont boot from correct disc
After installing HD, I accidentally inserted the wrong start up disc while trying to install OS. Obviously my laptop wouldn't let me install OS (from core 2 duo). Had to ejected disc on restart (wouldn't eject otherwise) and then powered off laptop.
Now I can't get my laptop to boot off correct install disc. Wont go past blinking ? file.
Tried powering on holding;
C key
option key
D Key.
Tried resetting NVRA/PRAM
No effect.
Laptop does chime on power up.
serial #W8622323THY
좋은 질문 입니까?
댓글 6개
This system can only go upto Mac OS-X 10.6.x Snow Leopard. What was the OS you were trying to install?
Dan 의
Are you using the Apple logo'ed CD or DVD? Or are you using the gray recovery disk that came with you're system (or the disk from the wrong system).
Dan 의
Do you have an external FireWire HD that is setup with a bootable OS on it?
Dan 의
I'm trying to reload my laptop with it's original apple install disc for my A1151 Intel Core Duo. I accidentally began to install my A1151 Intel Core Duo with the install disc for my A1226 Intel Core 2 Duo. Yes they are the original grey apple logo discs that they cam with.
clay 의
No I don't access to an external HD with a bootable OS on it.
clay 의
댓글 1개 더보기
