Water damaged iPhone 5, repeated alcohol cleaning, LCD backlight poor
Hi
I submerged my phone in swimming water for six seconds. As I was on holidays, my only option was to power down and bag it in rice for a week.
When I returned, I stripped down the phone and cleaned logic board with 95% ethyl alcohol. I also scrubbed all connectors. I can see a possible short/ damage on the LCD/ Logic board connector, I cleaned the area thoroughly.
Everything on the phone was working fine when I booted back up after this, however the LCD was "dim" and not bright.
I stripped it down again and cleaned the connectors, however on the next boot up the LCD was worse. I repeated and again it got worse and now it is extremely poor.
Is this a backlight coil/ IC issue now and should I bother trying to fix considering potential long term damage from water?
Thanks for you time
좋은 질문 입니까?
ppat, " I can see a possible short/ damage on the LCD/ Logic board connector" post a couple of images with your question so we can see what you see. Use this guide 기존 질문에 이미지 추가하기 to post images with your question
oldturkey03 의
Thanks for your response.
I will post a picture when I get home. The damage isn't getting worse so would that explain the continued deterioration?
ppat 의
Any chance you could repost some of your image. The motion blurr makes it look like that there are some pins missing.
oldturkey03 의
Sorry Old Turkey. Thanks for your response. Those pics were after a lot of attempts!
Perhaps the pins may be missing. It is hard to tell with naked eye even.
ppat 의
If those are missing pins, you will need someone to resolder a new connector to the board. That may be the reason why your backlight is not working properly
oldturkey03 의
댓글 1개 더보기
