주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
402 질문 전체 보기
How to fix backlight LVDS connector damage or baclight component
Hi, Is anyone can me? I have a macbook A1286 emc 2563 logic board number: 820-2915B which power on and we can ear the shime but no video and backlight. After looking at very well the lcd connector I saw that there are some pins (about 3 or 4) on missing on the logic board and the pins maybe burned I don't know why. I think it is the source of the problem, if itsn't what's the problem? Please I need the pinout of these missing pins to fix it when i'll change this connector by a new one.
regards
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Drickko, it's a definite that you will have to replace the connector. Yes, it most likely is the reason for your display not to come on. The bigger issue here will be why it burned like that. After you change the connector check the circuitry for short to ground etc. Contact 3 is the power to your LCD. your pins look like 40-36
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I don't know the reason why it burned like that... can I have the pinout of these missing pins (there are no pins on the logic board to solder these pins burned)? Where is located the lcd power on the board...?
You can not repair the individual contacts but have to replace the complete iPex 20474-040E-11 connector
댓글 달기
Mack pro A1286
this from damage place 4 pin is contact with soma place and the place is near light fuse under the ic light fast point
Update (10/12/2017)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Drickko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,655
