주요 콘텐츠로 건너뛰기
iPhone을 직접 수리하는데 필요한 모든 것! iFixit에는 모든 iPhone의 무료 수리 안내서 및 분해 정보는 물론 은하계 최고의 교체 부품 및 도구가 있습니다.
36444 질문 전체 보기
질문 마감됨
Glass replacement issue that nobody seems to know the answer to
So I don't know did anyone can answer this question but recently I have done an iPhone 6 and iPhone 5 glass replacement. After I cured the uv glue under a uv light I cleaned excess glue off and turned the phone on only to see that the screens were very discolored. I think this is because of the glue but I'm not sure if anyone knows why this happens please respond!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
looks like it got under the lcd :(
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi , this is the issue with cutting Iphone screens and using UV glue to attach a new one. the glue gets between the LCD and backlight. this is what causes what you are seeing. you will require a new backlight. An alternative to loca is OCA - Optically Clear Adhesive (Sticker but needs autoclave to remove bubbles).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Is there a way to prevent the glue from getting under the backlight and how does the OCA work or the autoclave
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 105
