주요 콘텐츠로 건너뛰기
Fourth generation Samsung Android tablets. Released in April 2014.
359 질문 전체 보기
doesn't always charge to 100%
I'm new to all this so bare with me. At first I could charge it to 100% and now it only charges to less than 50%. I read on line that this could be fixed by resetting it and I did and it would go back to charging 100&. After a few successful charges it returned to only charging to 50%. If I don't follow the reset instructions it won't charge completely. I've even left it on chargefor an extended amount of time but it still doesn't fully charge. What can I do to fix this? I appreciate your help in this matter.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
This most definitely sounds like your battery has failed. A replacement would help fix the issue and if not then you will have ruled out the battery as the issue and then can continue to troubleshoot further.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
SUSAN HOLMES 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 961
